UART -Digital I/O control
Digital I/O control using strings with arduino mega
This is a series of simple projects aimed at getting started with Arduino. This will cover most of the important peripherals of the Arduino starting from simple Digital I/Os and serial communication interfaces.
1:UART-Digital I/O control using serial port.
2:UART-Digital I/O control .
3:UART-Digtial Thermometer.
4:UART-PIR sensor intruder detection.
Digital I/O control using strings:
connect the led to pin 13 and power supply 5v and ground
if the input is given as a string 'on' the led turns on
and if the input is given as string 'off' the led turns off.
