Display potentiometer read Nokia 5110 LCD
This example shows you how to read analog input using a potentiometer, display absolute read value, convert to volts and turn on/off display backlight using interrupt.
Hardware required
- Arduino Board
- Nokia 5110 84x48 pix LCD Display
- 10 KOhms Potentiometer
- 10 KOhms resistor
- Pushbutton
- Breadboard
- 13 Jumpers male to male
- 3 jumpers female to male
Software requirements
- Adafruit-PCD8544-Nokia-5110-LCD-Library
https://github.com/adafruit/Adafruit-PCD8544-Nokia-5110-LCD-library
- Adafruit-GFX-Library
https://github.com/adafruit/Adafruit-GFX-Library
Circuit
1) Nokia 5110 LCD Display
- Arduino Pin 12 do Arduino connected to display pin 1 (RST)
- Arduino Pin 11 do Arduino connected to display pin 2 (CE)
- Arduino Pin 10 do Arduino connected to display pin 3 (DC)
- Arduino Pin 9 do Arduino connected to display pin 4 (Din)
- Arduino Pin 8 do Arduino connected to display pin 5 (Clk)
- Arduino VCC to display pin 6 (Vcc)
- Arduino Pin 7 connected to display pin 7 (BL)
- Arduino GND connect to display pin 8 (GND)
2) Potentiometer
- Arduino GND connected to one of the outer pins of potentiometer
- Arduino 5 volts (VCC) to the other outer pin of potentiometer
- Arduino Analog Pin A0 to the middle pin of potentiometer
3) Pushbutton
- Arduino GND connected to one of the legs of pushbutton through 10 KOhms resistor
- Arduino 5 volts (VCC) connected to anoter leg of pushbutton
- Arduino digital pin 2 to oposite leg of pushbutton
