No projects found for tag 'basic push buttons and le'. Showing all projects instead.
Distance Calculator with Arduino and LCD Display
It calculates the distance with the help of HC-SR04 Ultrasonic sensor and displays the distance in centimetres in the 16*2 LCD Display.
This project is used to calculate the distance from itself to any desired place.
Pin out details:-
HC-SR04 Ultrasonic Sensor
VCC to Arduino 5V
GND to Arduino GND
Echo to Arduino pin 8
Trig to Arduino pin 13
LCD Display (I used JHD162A)
VSS to Arduino GND
VCC to Arduino 5V
VEE to Arduino GND
RS to Arduino pin 12
R/W to Arduino pin GND
E to Arduino pin 11
DB4 to Arduino pin 5
DB5 to Arduino pin 4
DB6 to Arduino pin 3
DB7 to Arduino pin 2
LED+ to Arduino 5V
LED- to Arduino GND
