The tag 'esp-07' is only used once. This is the project:
DIY Light Sensor
A DIY light sensor kit with a 555 timer and a LDR.
A DIY light sensor kit using a NE555 timer and a LDR. Also you will need 1kΩ resistor, 10kΩ resistor, 22kΩ resistor, 10nF ceramic capacitor, 100nF ceramic capacitor and a 100kΩ potensiometer.
The output of the sensor can be obtained from the middle pin of the 3-pin connector.
