Please login first.
fischertechnik ROBO TXT Controller
fischertechnik ROBOTICS TXT Controller (90x90x25mm)
- Processor: Dual core, main processor ARM Cortex A8 (32bit/500mHz) + Cortex M3
- Memory capacity: 128 MB DDR3 RAM, 64 MB Flash
- Memory expansion Micro SD card slot
- Display: Color 2.4“ touch display (320x240 pixels)
- 8 Universal inputs: Digital/analog 0-9VDC, analog 0-5 kΩ
- 4 high speed numerical inputs: Digital, frequency up to 1kHz
- 4 Motor outputs 9V/250mA (max: 800 mA): speed infinitely controllable, short-circuit proof, alternative 8 single outputs for components such as lights, etc.
- Combined Bluetooth/WiFi RF module: BT 2.1 EDR+ 4.0, WLAN 802.11 b/g/n
- Infrared receiver diode: for fischertechnik Control Set transmitter
- USB 2.0 Client: Mini USB port for connection to PC
- USB Host interface: USB A port for fischertechnik USB camera, USB sticks, etc.
- Camera interface: over USB Host, Linux camera driver integrated into operating system
- 10-pin male connector for additional inputs and outputs as well as I2C interface
- Integrated loud speaker
- Integrated real time clock with exchangeable buffer battery: for capturing measured values within a defined period of time
- Linux-based open source operating system
- Programming possible with ROBO Pro, C-Compiler, PC-Library, and many others.
- Link to smartphones/tablet PC‘s via Bluetooth or WLAN, allowing them to be used as terminals for the controller.
- Programming using ROBO-Pro software.
- Dimensions: 90x90x25 mm
- Power supply: 9V DC 3.45 mm socket, or 2.5 mm fischertechnik sockets (for Accu Pack)
