Flyport WebServer with SHT71 Sensor
The Flyport gets the temperature and humidity from the sensor and send them to webpage.
This application is a WiFi WebServer with the SHT71 Sensor. The Flyport module reads the values of temperature and humidity through I2C compatible bus and send them to webpage. Connections: o1 = clock_pin o2 = data_pin
