four-way tilt activated LED (buoy project)
a simple experiment with Parallax 4-direction tilt sensor (#28036). illuminate a different color LED based on the physical orientation of your project. I am attempting to make a buoy also makes a fun piece to a game if you rotate the part body
Parts list:
1 Arduino Uno
1 bread board
1 4 direction tilt sensor Parralax (Product ID 28036) I bought from Microcenter
4 100Ohm resistors
4 LED(different colors)
see the the Link 4-direction tilt sensor from parallax
to figure out which way to oreintate your 6 pin sensor on bread board.
*Hint on the sensor there is text that reads "RevA" that is the up direction of the sensor. Opposite of RevA is down or gravity.
Next wire your board according to the fritzing diagram
Upload the code I have provided to your Arduino.
you are ready to go
works well with a battery
