hand position sensor
use 3 light sensors to work out the position of your hand over them
in this project you will use 3 light sensors and an LCD screen to work out the position and hight og you hand above them. this could have uses in things such and games.
parts list
- 27 x solderless wires
- 4 x 220ohm resistors
- 3 x light sensors
- 1 x LCD
- 1 x potentiometer
- 1 x arduino
- 1 x bread board
note : if downloading the code from code viewer you need to change all the values of 20 in the if statements to 15
