Interfacing DUE with DUE through I2C
I2C is a communical protocol which is used to communicate with I2C devices by using only two wires namely SCL and SDA
I2C communication uses two signal wire namely SCL and SDA .
For interfacing DUE with DUE we have to assign one as master and another one as slave.
Master:Burn master code from wire library to one DUE board
Slave :Burn Slave code from Wire library to another Library code
