IR Sensor Shield
Its a simple and usefull tiny construction, to connect a Nano, a standard IR Sensor and a 220V Relais.The Arduino can be run with USB Power.Or it has a connection to a Power Supply as well. With a normal IR Remote you can switch any 220V Device on and off.Anything wrong? To easy? Just let me know.Have fun!
You will need:
1x Arduino Nano
2x Screw Connector 3
1x Screw Connector 2
1x IR Sensor
1x 220V Relais
1x 12x22 Dot Shield
8x Wires on Board
6x Wires / each 3 for Sensor and Relais
Just connect everything the way shown in the picture:
Red is Power.
Black is Mass.
Yellow is Signal.
Green is Signal.
Runs with every IR Remote.
