Jack O'Lantern with animated eyes
This project is a Halloween pumpkin with two LED matrix displays showing animated eyes.
Halloween is comming up so I made a Jack O'Lantern with LED Matrix displays. I used displayes equipped with a MAX7219 IC. It is very straightforward to use it and the modules can be arranged in a row.
You will need the LedControl library in order to run the code. Have fun and check my website StartHardware.org to find more interesting projects :-)
