LDR light controller
LDR light controller using arduino mega
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to see
LDR light controller:
connect the LDR as analog input to the pin A0.
and the AC bulb using a relay which is connected to pin 50 and 5V power supply and ground.
when the room is dark the AC bulb turns on or else the bulb turns off
