LED BLINKING using arduino
LED BLINKING USING ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to see
LED BLINKING:
Turns on an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the Uno and
Leonardo, it is attached to digital pin 13. If you're unsure what
pin the on-board LED is connected to on your Arduino model,
check
the documentation at http://arduino.cc
