LED Driver in SMD (for RC models)
This is my first attempt at Fritzing and I designed an LED SMD driver PCB that can be incorporated into RC models for lighting.
THe LED driver uses 2 SOT-23 transistors (type t.b.d.) and 2 resistors plus the connections to the outside via pads. It is a single sided pcb.
