LED ON/OFF using PIR SENSOR
LED ON/OFF WITH PIR SENSOR USING ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to see
LED ON/OFF using PIR sensor:
connect the led to pin 13 and pir sensor to pin 3 and 5V power supply and ground.
when the pressure increases led turns on else off.
