Message on a 16 Segment Display
Display a message on a single common anode 16 segment display. Based on the LTP587HR.
Parts:
Arduino board
Jumpers
16 Segment Display (LTP587HR)
Program:
Build:
After programming the Atmega connect the Arduino pins (2-11) to the 16 segment pins (H, G, U, P, C, D, T, M, S, F) *note: for the simplest project only the segments needed to display 'Hello' were used.
When modifying the project you may need all or different segments.
