Moto_Moped_Scooter speed limiter
Limits your moped to exceed desired max speed by cutting spark.
Not all components are in real life like in schema drawing, see the text fields around components.
Actually used A-Star 32U4 Micro ( No fritz model :-/ )
Some moped and scooters might not like that ignition coil signal is routed directly to ground, prevent spark. But this is typically how moped engine shutdown buttons work.
