Northern Lights RGB Painting
A mixture of painting and programming :) I came up with this idea when I couldn't find many creative ways to use individually addressable LED's online. The project uses WS2812B Neopixel LED's, some plywood, and some basic programming to turn Bob Ross's Northern Lights painting into living art.
Since there's alot of self-explanatory steps to this project, I will keep the instructions pretty brief.
1. What you need
Supplies
- Arduino Nano (rev3)
- Perf Board/ Bread Board
- 5v ~1A Power Supply (I used an ordinary USB wall charger and a USB charging coard with a barrel jack output)
- Assorted Wires (I recommend 22 AWG or thinner to make soldering easier)
- 3x - 470 ohm resistors (anything around that will do)
- atleast 12V, 1000µF capacitor
- 3/8" plywood (main board is about 21x31", then some extra wood for the frame)
- cardboard
- white + glossy spray paint
- nails/screws/hanging hardware
Tools
Dremel + sawblade bit (or whatever works to make the cuts for the LED's to shine through)
- Circular Saw
wood glue
- soldering iron
- exacto knife
- hammer
- drill
- hot glue
Other
- painting stuff for bob ross northern lights (google it, easy to find)
- Arduino IDE + FastLED library
2. Preparing the wood
The first step in building the project is to cut the plywood that will be the painting, I decided to kind of eyeball it; that's the beauty of art, nothing has to be perfect. Mine ended up being approx. 21x31". I used a circular saw for this, and then sanded the edges.
Next, I sketched the outline for the northern lights, MIRRORED, on the side BACK SIDE of the wood, so that the messy parts of cutting with the dremel wouldn't show on the painting side. After I had a rough outline of the area that I wanted to cut, I used the Dremel with the sawblade bit to make slits in the wood. This was alot slower and tedious than I thought it would be, but atleast I can give you some tips if you plan to use the same method: 1. Don't just make all of you cuts the same length, It looks better if they vary. 2. You can always sand the slits to make them wider, so don't mess up the entire project by accidently cutting into another slit. 3. If you look at mine, I have a lot of cuts in the middle where I just used a hand saw from the edge of the wood. These were way easier and quicker cuts, just don't go overboard or you won't have the wave-shape anymore. After all the cuts were made, I moved on to the electronics.
3. Making/ incorporating the LED's
When I first started messing with the LED portion, I planned on using a neopixel strip that I already had. I changed my mind when I realized that the LED's too spaced out and the color wave effect wouldn't look good with so few lights. So, I decided to solder my own using the same WS2812B LED's. You can buy your own, and maybe even get a strip that has smaller/ close-together LED's for a better effect, but if you do solder your own, try not to use more than 1 inch of wire in between them. As for how many LED's you use per strip is up to you. This is the convenient part of creating your own strip: you don't have to have to cut a pre-made strip that leaves an akward inch of space at the end of the wood slits where there's no LED. I made 3 strips (17-17-32 LED's) using 66 LED's total. One strip for each separate chain of the northern lights. I used cardboard/ wood to create a sort of mounting rail for the LED's bellow each set of northern lights (palce the cardboard perpendicular to the wood, so that the lights point UP when the painting is hanging on the wall). I also cut out a piece of cardboard which I spray painted glossy white and then placed it behind the entire area containing the LED's. This helped reflect the lightfrom the LED's, as well as keep the colors of one set of northern lights from bleeding into the other 2 (make sure all the cardboard for the LED-rail portions are the same width, so that the white back-piece rests evenly over them to better seal each strip of lights off from eachother). I used hot glue to secure all cardboard pieces, as well as the LED's to the cardboard rails.
4. The Electronics
The fritzing sketch shows how to assemble the electronics, and the code is commented, so there's not much to say about it here. Just pay attention to keeping the wires out of the way so they dont cover your northern-lights slits. Use hot glue where you can to route the wires. For the power supply, I used an ordinary USB-charging box and cord. these are rated for 5v-1A, and the WS2812B's use 5v. To decide on which of the 6 USB boxes to use, I plugged each one into the wall, and used a multimeter to measure which one most consistently output closest to 5V with the cord I intended to use. Most of them would've worked, so don't freak out too much about this part. 1A should be enough unless you use alot more LED's (I used 66 LED's and they drew 0.65-0.7A). It goes without saying, but if you don't have a USB to Barrel jack wire, you can just cut and solder one together (I'm being vague with parts of the project that you can easily google, like this). IMPORTANT** Never connect the Nano via USB and 5V at the same time, you will fry it. If you're uploading code, make sure the 5V power is off or disconnected.
5. The Painting
Before I painted, I cut out a frame with scrap wood to ugliness on the back of the project when its hanging on the wall. This is a personal preference and the dimensions of the fram are up to you. I did ~ 1.5" thick, cutting a whole for the barrel jack power input and staining it before I used wood glue and clamps to put it on the main piece of wood.
Only the man himself can give you the painting part of the tutorial :)
https://www.youtube.com/watch?v=vgbMONXc9Cs
Note: I painted the whole back with black acrylic, being careful not to get too much paint in the lights-slits.
6. Final Steps
The last thing I did was use wood glue and tiny nails to put the 2 large pieces of wood on the back of the painting. This made it so that the painting rests evenly against the wall, far enough off tof it so that the arduino parts aren't damaged by the wall itself. It also gives you a spot to attach mounting hooks/ brackets, if you plan to.
This was my first tutorial, so let me know if anything was unclear. I figure if you're like me, you want to put your own personal touch on parts of the project anyway, so I skipped some of those decision-based details here and there. Hope you guys like it!
