Obstacle Avoiding Robot
ITS ABOUT Obstacle Avoiding Robot CAR SEES OBSTACLES AND AVOID THEM ITS THAT SIMPLE
you will make obstacle avoiding robot. This tutorial involves building a 4WD robot with an ultrasonic sensor that can detect nearby objects and change its direction to avoid these objects. The ultrasonic sensor will be attached to a servo motor which is constantly scanning left and right looking for objects in its way.
Required Hardware :
Arduino Board - https://goo.gl/UyGYeF
Motor Shield L293D - https://goo.gl/9Ph44b
Ultrasonic Sensor - https://goo.gl/dRkWUg
Mini Servo Motor - https://goo.gl/Hxejko
DC Motor and Wheel x4 - https://goo.gl/rpxoMu
Chassis 4WD - https://goo.gl/GeBWs1
Bracket for HC-SR04 - https://goo.gl/1RrOgP
Battery Buckle x2 - https://goo.gl/aBKusM
Wires - https://goo.gl/TdGrkk
Button
Glue Gun
Battery 9V x2
