PICAXE compatiblity board
With this board you can connect PICAXE 8M2, 14M2, 18M2 and 20M2 or 20X2
I checked the pinouts of each PICAXE and I found a patter, so I decieded to make a board that uses a 20 pins ZIF socket, a couple of dip switch, some resistors, som SIL and extra componentes.
One dip switch select 8,14 and 20 pins PICAXE and the other select the 18 pin PICAXE
