The tag 'sensor con sumbador' is only used once. This is the project:
PIR sensor and Photocell Mix
This circuit uses the Arduino nano along with a photocell and a PIR sensor. Using the analog read command the photocell sends info to the Arduino of how mucj=h light is in the room. the PIR sensor sends an alert to the serial monitor when motion is detected.
I will update the details soon enough. :)
