Potentiometer as ADC input display serial monitor
potentiometer as ADC input using ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to
Potentiometer as ADC INPUT:
connect a potentionmeter as analog input to pin A0 and 5V power supply and ground supply
and measure the values in serial monitor by varying the potentiometer.
