No projects found for tag '#raspberry #power #button'. Showing all projects instead.
A Raspberry Pi control for your LED RGBW strips
This project consists of a Python 3 application and a hardware part and is intended for controlling standard (non-adressable) RGBW LED strips with a Raspberry Pi Zero or above. You can use a HTML web interface and/or any infrared remote control to switch it on or off, to customize hue, saturation and value, to set the brightness, or to select a colour preset. There is also an automatic mode which controls the LED colours depending on time sections referring to sunrise and sunset daytime.
See the project homepage on sourceforge for details.
