The tag 'meterology' is only used once. This is the project:
Relay Breakout
An (Mini PCB) Relay (T73) Breakout for general use.
An simple Mini PCB Relay T73 (5V, 12V, 24V) Breakout for general use.
Shopping List
3 - Screw terminal - 2 pins
1 - LED1 Red LED - 5mm
1 - R1 220 Ω Resistor (for 5V only!)
1 - RELAY Relay T73
http://youtu.be/lhC5wBnlHYA - Demonstration
