RelayPilot V2
A NodeMCU (ESP8266) Shield to control relay on "fil pilote" for french home heater system. Based on Arduino for ESP8266 WIFI AP Mode for configurationWIFI Client for sendind data to domoticz Rest Control API for switching heating Mode Parts required: 1 Double 5V-230V relay module 1 DS18B20 thermal temperature sensors Wires for 230V (input, relay in/out, control wire) 1A Fuse for 230V input
RELAYPILOT V2
FIL PILOTE REMOTE CONTROL WITH ESP8266, HTTP COMMAND and DOMOTICZ INTEGRATION for temperature
USAGE:
http://IP/temp : Show current temperature from DS18B20 sensors
http://IP/settings: Change device setting( host domoticz, port, ssid wifi, wifi password, etc...)
http://IP/confort: Heater confor mode
http://IP/eco: Heater ECO mode
http://IP/hors-gel: Heater hors-gel mode
http://IP/APMode: AP Mode to edit settings
http://IP/reboot: Reboot le module
