RFID Servo Locking Mechanism
A simple locking mechanism that was designed to work inside an Picup truck canopy.
This was designed to work ontop of a ute canopy lock and replace the key. In many canopies the key simply lifts a pin that prevents the handle from being turned. The key barrel is often a weak point and can be forced to turn without a key. I play on removeing the key locks, lifting pin, and lift it electronically using a small servo motor. This is a first prototype and might still need some changes later down the line inluding mounting options and backup entry options should anything fail.
