No projects found for tag 'tft3'. Showing all projects instead.
RGB LED board with resistor
can be used to minimize space on bread board to connect a rgb led to. Includes resistor. Can be plugged into an arduino without any wires. pinout: (GND, RED, GREEN, BLUE).
Solder red to blue pin towards the header pins on the board with red being the closest to the pins.
rest is pretty self explanatory.
