RUNNING LED'S when button pressed
RUNNING LED'S when button pressed using ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this experiment we are going to see
RUNNING LED'S when button is pressed:
connect different LED'S to pin 9,10,11 and a push button to pin 3 and 5V power supply and ground.
