Seesaw Car
The goal of this project is to balance an arduino programmed cart autonomously, to balance a Seesaw.
Group Member Names: Dalton Ellis, Jason Ross, Justin Valentine, Ken Aoyagi
Course and Quarter: ENG114
Date: 12/7/2019
Revision Number:
Seesaw Car
Problem Statement:
Our group chose to use an electric motor car to balance a Seesaw.
Hardware Setup
Materials:
Bill of Materials:
Part Name
Purpose
Item Name
URL
Price
Redboard
Microprocessor
Arduino Uno
https://www.sparkfun.com/products/15123
$20
Arduino and
breadboard holder
Base for breadboard
Arduino and breadboard holder
https://www.sparkfun.com/products/11235
3.95
Motor driver
Controls voltage levels to motors
Dual TB6612FNG
https://www.sparkfun.com/products/14450
5.45
accelerometer
Sensing pitch level
MPU 92/65
https://www.banggood.com/buy/mpu-9265.html
12
Hobby gearmotor
Moves vehicle
DG01D
https://www.sparkfun.com/products/13302
4.95
Wheels
Provide rotational inertia and minimal points of contact to board
Wheel
https://www.sparkfun.com/products/13259
2.95
Seesaw
Tilt car
Seesaw
HOMEMADE
N/A
Jumper wires
Facilitates flow of electrons with minimal resistance
Jumper wires
https://www.sparkfun.com/products/11026
2.25
Mini power switch
Turns off power
Mini power switch SPDT
https://www.sparkfun.com/products/102
1.50
Hookup Guide:
Redboard
Motor Driver
Digital 11
PWMA
Digital 12
A12
Digital 13
A11
Digital 10
PWMB
Digital 8
B11
VIN
VM
5V
STBY
Left motor
Motor driver
Black wire
A02
Red Wire
A01
Right motor
Motor driver
Black wire
B02
Red Wire
B01
Accelerometer
Redboard
SCL
Analog A5
SDA
Analog A4
Arduino Code:
SparkFun Inventor’s Kit
Circuit 5B - Remote Control Robot
Control a two wheeled robot by sending direction commands through the serial monitor.
This sketch was adapted from one of the activities in the SparkFun Guide to Arduino.
Check out the rest of the book at
https://www.sparkfun.com/products/14326
This sketch was written by SparkFun Electronics, with lots of help from the Arduino community.
This code is completely free for any use.
View circuit diagram and instructions at: https://learn.sparkfun.com/tutorials/sparkfun-inventors-kit-experiment-guide---v40
Download drawings and code at: https://github.com/sparkfun/SIK-Guide-Code
#include "MPU9250.h"
// an MPU9250 object with the MPU-9250 sensor on I2C bus 0 with address 0x68
MPU9250 IMU(Wire,0x68);
int status;
//the right motor will be controlled by the motor A pins on the motor driver
const int AIN1 = 13; //control pin 1 on the motor driver for the right motor
const int AIN2 = 12; //control pin 2 on the motor driver for the right motor
const int PWMA = 11; //speed control pin on the motor driver for the right motor
//the left motor will be controlled by the motor B pins on the motor driver
const int PWMB = 10; //speed control pin on the motor driver for the left motor
const int BIN2 = 9; //control pin 2 on the motor driver for the left motor
const int BIN1 = 8; //control pin 1 on the motor driver for the left motor
int switchPin = 7; //switch to turn the robot on and off
const int driveTime = 20; //this is the number of milliseconds that it takes the robot to drive 1 inch
//it is set so that if you tell the robot to drive forward 25 units, the robot drives about 25 inches
const int turnTime = 8; //this is the number of milliseconds that it takes to turn the robot 1 degree
//it is set so that if you tell the robot to turn right 90 units, the robot turns about 90 degrees
//Note: these numbers will vary a little bit based on how you mount your motors, the friction of the
//surface that your driving on, and fluctuations in the power to the motors.
//You can change the driveTime and turnTime to make them more accurate
String botDirection; //the direction that the robot will drive in (this change which direction the two motors spin in)
String distance; //the distance to travel in each direction
void setup()
// serial to display data
Serial.begin(115200);
while(!Serial) {}
// start communication with IMU
status = IMU.begin();
if (status < 0) {
Serial.println("IMU initialization unsuccessful");
Serial.println("Check IMU wiring or try cycling power");
Serial.print("Status: ");
Serial.println(status);
while(1) {}
pinMode(switchPin, INPUT_PULLUP); //set this as a pullup to sense whether the switch is flipped
//set the motor control pins as outputs
pinMode(AIN1, OUTPUT);
pinMode(AIN2, OUTPUT);
pinMode(PWMA, OUTPUT);
pinMode(BIN1, OUTPUT);
pinMode(BIN2, OUTPUT);
pinMode(PWMB, OUTPUT);
void rightMotor(int motorSpeed) //function for driving the right motor
if (motorSpeed > 0) //if the motor should drive forward (positive speed)
digitalWrite(AIN1, HIGH); //set pin 1 to high
digitalWrite(AIN2, LOW); //set pin 2 to low
else if (motorSpeed < 0) //if the motor should drive backward (negative speed)
digitalWrite(AIN1, LOW); //set pin 1 to low
digitalWrite(AIN2, HIGH); //set pin 2 to high
else //if the motor should stop
analogWrite(PWMA, abs(motorSpeed)); //now that the motor direction is set, drive it at the entered speed
void leftMotor(int motorSpeed) //function for driving the left motor
digitalWrite(BIN1, HIGH); //set pin 1 to high
digitalWrite(BIN2, LOW); //set pin 2 to low
digitalWrite(BIN1, LOW); //set pin 1 to low
digitalWrite(BIN2, HIGH); //set pin 2 to high
analogWrite(PWMB, abs(motorSpeed)); //now that the motor direction is set, drive it at the entered speed
void loop(){
if(digitalRead(7) == LOW){
IMU.readSensor(); // read the sensor
float y = IMU.getAccelY_mss();
while (y!=-2.501){
Serial.print("AccelY: ");
Serial.print(IMU.getAccelY_mss(),6);
Serial.print(" ");
Serial.println();
delay(100);
Serial.print(y);
Serial.print(" ");
Serial.println();
/*The following section of code is designed to create a running average of values from the accelerometer. This was necessary to eliminate spikes in torque that created problems that caused t
*the car to jerk back and forth in a way that did not allow for proper balance.
float prev_y1 = y;
delay(10);
float prev_y2 = y;
delay(10);
float prev_y3 = y;
delay(10);
float prev_y4 = y;
delay(10);
float prev_y5 = y;
delay(10);
float prev_y6 = y;
delay(10);
float prev_y7 = y;
delay(10);
float prev_y8 = y;
delay(10);
float prev_y9 = y;
delay(10);
float prev_y10 = y;
delay(10);
float prev_y11 = y;
delay(10);
float prev_y12 = y;
delay(10);
float prev_y13 = y;
delay(10);
float prev_y14 = y;
delay(10);
float prev_y15 = y;
delay(10);
float prev_y16 = y;
delay(10);
float prev_y17 = y;
delay(10);
float prev_y18 = y;
float avg_y = (prev_y1 + prev_y2 + prev_y3 + prev_y4 + prev_y5 + prev_y6 + prev_y7 + prev_y8 + prev_y9 + prev_y10 + prev_y11 + prev_y12 + prev_y13 + prev_y14 + prev_y15 + prev_y16 + prev_y17 + prev_y18) / 18;
if (avg_y >= -2.8 && avg_y <= -2.2) // if statement to decide direction, seems to not recieve data from the accelerometer
rightMotor(0); // drive the right wheel forward
leftMotor(0);
Serial.println("motorstuff"); // drive the left wheel forward
// delay(driveTime * distance.toInt()); // drive the motors long enough travel the entered distance
// rightMotor(0); // turn the right motor off
// leftMotor(0);
else if (avg_y > -2)
rightMotor(80); // drive the right wheel forward
leftMotor(80); // drive the left wheel forward
else if (avg_y < -3)
rightMotor(-80); // drive the right wheel backward
leftMotor(-80); // drive the left wheel backward
else
continue;
Results:
Our result was that after some experimenting with the mechanics of the seesaw and the code we were able to successfully make our car automatically move to balance the seesaw.
Future Work:
If a future group wanted to improve on this project they could do it in a number of ways. Our group was able to make the seesaw function as planned but we did have to include some rubber bands to create tension under the board that makes the seesaw move slower. A future group could improve on our project by gradually increasing the speed of each motor immediately after a direction change so that the wheels don’t peel out and the car could theoretically balance the motor faster.
They could also incorporate a certain amount of machine learning so that the car could learn on it’s own when to correct direction.
They could also incorporate code to correct for motor directionality so that the car could stay straight without human correction.
License
Electric Car for Balancing a Seesaw
Copyright (C) 2019 J. Valentine, K. Aoyagi, D. Ellis, J. Ross
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <https://www.gnu.org/licenses/>.
