Sensor ldr indicando tres niveis de luz usando LDR
Ldr sensor indicating three levels of light and can be used in many projects.
Ldr sensor indicating three levels of light and can be used in many projects, levels of drives can be changed by changing the values of the bonds if, else if and else. Use the serial monitor to read the values of the LDR.
