The tag 'through hole' is only used once. This is the project:
Simple IR Remote Tester
This is a simple ir remote tester. You can test to see if TV Remotes, Infared Remote Controllers, etc, etc, will work. Just order the pcb or build the circuit yourself on a perf board through the scematic.
