Small Led Light
A small LED light that you can use to help teach or learn the basics of electronics.
What you will need is (a) battery(s) and someting to connect it to the board, a resistor (depends on the battery you use), a led, and a switch.
Steps:
1: Get the materials you need
2: Solder in the componets with the cathode (-) of the LED facing oof of the board and the cathode (-) of the battery facing to the resistor.
3: Have fun with your new light!
This can be used to teach or learn about open and closed circuits.
