Please login first.
Smart Home with different sensors
This is the project where we see the different sensors such as temperature sensor , gas sensor and ldr (light dependent resistor) these are put to gather and made necessary code and conections on aurdino to bring the output
The tools required are the
aurdino , temperature sensor (dht11) , gas sensor , led and ldr
make the appropriate connections as per the circuit diagram
send the code to aurdino from the aurdino software
its so simple to make and its of effordable cost
NOTE :- we need to download the library of dht11 sensor to run the code
