Sound Boy
A Portable, Chargable Stereo Amplified Speaker
This project is based around the Mini-D from jaycar, In the fritzing file I have layed out all the wires with how i set it up.
the white dots and squares in the lables are the sections you need to cut out.
Please refer to the video link here.
https://youtu.be/EKXGJBPvaJM
Here are the components i used with the Jaycar code
//case buttons lights
27mm knob HK7740
Bezel 5mm led red SL2610
Bezel 5mm led green SL2612
Mini Rocker Switch SK0984
Jiffy Box 197x133x63 HB6012
//main Speaker components
10W 8-Ohm Full Range Speaker x2 AS3032
Mini-D 2 x 10W Class-D Amplifier Kit KC5530
8 AA Battery Holder PH9209
//sound input
3.5 stereo chassis socket PS0132
RCA Chassis Socket - red PS0259
RCA Chassis Socket - White PS0261
//Mounting and support
PC Boards HP9542
Rubber feat HP0816
25mmx3mm steel screws HP0414
3mm steel nut HP0425
Washers HP0433
Nylon Spacers HP0815
Here is the schematic for the charging circuit
http://www.talkingelectronics.com/projects/200TrCcts/101-200TrCcts.html#84B
