Temperature controller
Temperature controller using ARDUINO MEGA
1.LED BLINKING
2.LED ON using push button
4.Running LED'S
9.LDR light controller
11.Temperature controller
In this we are going to see
Temperature controller using LM35:
Connect LM35 as ADC input to pin A0 and connect a fan as output to the pin 50 and 5V power supply and ground
when the temperature level incresaes fan turns on or else off.
