Temperature & Humidity display
Takes data from DHT11 and displays it on Nokia5110 LCD.
If only i knew what to write here.
It's pretty easy to built.
Resistor u need is 10kOhm. But if DHT doesn't works fine u can replace it with lower resistance one.
For example i use 1.1kOhm.
I used two half sized breadbords to make it look better.
