Temperature logger on SD Card
Record up to 16 different sensors, repeatively, on an SD card, on a file with CSV format, The format makes the file usable in a spreadsheet program.
Detailed instructions given in French in the joined file.
The item is able to:
have several sensors: 1 to 16+ plugged all together
Auto-config of number of sensors
Digital sensors DS18B20, from -40°C up to +125°C
LED is flashing at each measurement
Live recording of measurements on the micro SD card
CSV File format (to be used in spreadsheet programs)
A new file at each power up (does not destroy previous files)
File name customisable in config file on SD card
Recording sequence length customisablein config file on SD card
mesurements step adjustable in config file on SD card
Automatic creation of config file when does not exist
Power up switch makes measurements starting immediately
Autonomous, on rechargeable battries, and easily transportable
