tilt sensors control LEDs
use 2 tilt sensors to turn on and off 2 LEDs.
using 2 tilt sensors to control 2 LEDs. this depends on what way you tip the bread board. tilt sensors need to be bend to that the lay down flat on the bread board.
parts list
- 12 x solderless cables
- 2 x LEDs
- 2 x 220ohm resisters
- 2 x tilt sensor
- 2 x 10k ohm resisters
- 1 x bread board
- 1 x arduino
