Tilt Switch Activated LEDs Arduino
Turns on and off a light emitting diode(LED) connected to digital pin 13 and 12, when activating the Tilt Switch or a pushbutton attached to pin 2. When the tilt switch gives the Arduino the Off Signal, LED12 Will Switch off and LED13 will turn on.
Tilt Switch or Button Activated LED's
---How To Connect your switch to Digital pin 2
LED1 to Digital Pin13 and LED2 to Digital Pin12
Connect the switch Via a 100K Resistor to the 5V Pin on the Arduino
Connect Led ground to any ground on the Arduino board
The circuit: * LED attached from pin 13 to ground * LED attached from pin 12 to ground * pushbutton attached to pin 2 from +5V * 10K resistor attached to pin 2 (switch/button) from ground
Note: on most Arduinos there is already an LED on the board attached to pin 13.
created 31/12/2013 by Ryner GeekSpot http://www.GeekSpot.co.za modified 30 Aug 2011 by Lulouch GeekSpot
For bugs or help email: [email protected] or [email protected]
Tested by Ryner and Eesa 2013-12-31
