RFID MusicPlayer with Molex connectors
A Tonuino Clone, which has all the peripheral connections with footprints suitable for molex connectors. - UNTESTED -
All Connectors are with 2.54mm distance.
See original projects website https://github.com/xfjx/TonUINO (no support provided for this board!)
If you need a simple solution and community support, please get the official board from
https://www.voss.earth/tonuino/
This is currently untested, so check before building/ordering! If you are unsure how to do this, please get the official board (see above)!
If you do not want to use a switch, bridge the connector.
