Ultrasonic Sensor to LED Display of Distance
Finding range of a distance and then display it of a LED scale.
Arduino UNO Rev3(most will work with this i used the uno)
1x Half Breadboard
10x 5mm LED
10x 560 Ohm resistors
15x Jumper wires (if you don't have a pwm add 3)
1x PWM wire (Normal male to female header pins)
1x 3-pin Ultrasonic range finder(i got mine from RadioShack, you can also get them other places)
