No projects found for tag 'cam'. Showing all projects instead.
Unbricking Teclast x98 Air w Raspberry Pi
Raspberry Pi is running Raspbian and installed with Flashrom 0.98 and enabled SPI.
A SparkFun Breadboard Power Supply Stick - 5V/3.3V PRT-13032 would provide 1.8V supply for the Winbond W25Q64.W chip.
A SparkFun Logic Level Converter - Bi-Directional
BOB-12009 would convert the signals from Raspberry Pi from 3.3V to 1.8V
A Ponoma 8 pin SOIC clip is used to conduct in system flashing on the Winbond chip on the tablet.
Command ran on the Raspberry pi model A
./flashrom -p linux_spi:dev=/dev/spidev0.0,spispeed=512 -c <chip name> -r dump1.bin
