Water Level Indicator with no microcontroller
A simple circuit using npn transistors and LEDs for indicating with copper wires as sensrors in a water tank. When the water surface touch the beginning of any wire, the LED connected with turns ON and so on ...
Advanced Trials:
You can modify that circuit by adding 7-segment display, Buzzer for sound indication, and many other components which make your design more powerful ...
