WiFi sensor with two inputs for One Asset Place
This is a WiFi sensor with two digital inputs and relay control of the WiFly shield
This Circuit uses a SparkFun WiFly Shield and a Beefcake Relay kit to give you reliable long-term control over a wireless two-digital-input sensor. The software that accompanies the circuit is designed to be used with www.oneassetplace.com - allowing you to have a dashboard view of whatever you are monitoring. Source code can be found at https://github.com/RalfieRoo/OAP_Arduino A step-by-step tutorial can be found at One Asset Place Tutorials
