Wire Pickit3 to Pic16F/18F MicroController
The circuit needed to program your Pic MicroController
In order to program you Pic Microcontroller, you should wire correctly the pins of the Pickit3 to the Pic16F/18F.
My goal for sharing is to save you same hours of research but it is not difficult.
Note:
-Vss and vdd of PIC should be linked to the corresponding pins of PickIt3
- You will need the Pickit3 Programmer . you should download it .
