Workspace Environment Monitor - enVMon
Ever care about the place you may spend one-third of a day? enVMon capture noise level, air quality, UV level, temperature and humidity.
This monitoring station will monitor the Ultra-Violet, sound level, temperature, humidity, air quality (CO2). All above parameters are the common factors on safety working environment.
The objective of this project is to place this monitoring station in the working environment and monitor it, compare it and send the notification when the parameters reach threshold.
